FULL version will not install on Win2k
cincura.net
Post by cincura.net »
Anne wrote:NEW INFO.. I have found that if I try multiple time to extract the SALAMAND.exe file, from the ss25rc2f.7z using the STANDARD version of Salamander, that the Salamand.exe file will sometimes extract without an error.
This could be also problem with RAM...
Jiri {x2} Cincura
Thank you for confirming the think with multiple extraction. It looks like there is some (random) bug in 7-zip extraction code. We should really switch to latest source code.
Thank you for your effort. We will release Salamander 2.5 RC3 during next week (and final version 2.5 two weeks later), please let us know if installation works on your computer.
cincura.net wrote:This could be also problem with RAM...
Good point! We are using this nice memory test: http://www.memtest.org/ with prebuild ISO images http://www.memtest.org/#downiso but I don't want to bother Anne anymore :)
Could you try the same extract-action using WinRar?
http://www.rarsoft.com/rar/wrar362.exe
cincura.net
Jan Rysavy wrote:Good point! We are using this nice memory test: http://www.memtest.org/ with prebuild ISO images http://www.memtest.org/#downiso but I don't want to bother Anne anymore :)
I'm using it too. But as you noticed, probably bug in 7z extraction.
Jiri {x2} Cincura
Anne
Post by Anne »
SelfMan wrote:Could you try the same extract-action using WinRar?
Using WinRAR 3.62 on the file ss25rc2f.7z gives two messages
"The archive is either in unknown format or damaged" or
"no archives found in selected files and folders"
depending on the action taken by WinRAR
Anne
Anne
Post by Anne »
I ran memtest 86 from floppy for about 12 hours before I reinstalled the OS.
No errors in my 512mb of mem
Anne
Anne
Post by Anne »
NEW INFORMATION
I changed my motherboard settings from OPTIMAL to STANDARD.
Now I can SOMETIMES get the ORIGINAL file "ss25rc2f.exe" to extract and install correctly with no errors.
This is the FIRST time I have been able to do this with the original .exe file since my reformat and reinstall of the OS.
Anne
It looks like some hardware dependent problem. Did you notice other unusual problems with your computer?
Anne
Post by Anne »
Jan Rysavy wrote:It looks like some hardware dependent problem. Did you notice other unusual problems with your computer?
No, did not notice any other problems other than Salamander.
It looks to me like a timing issue with the extraction process and the particular file. I have had no other problems with file extractions.
I continue to install other software and everything works just fine.
