C++ bridge for C# plugins
KRtek™
Post by KRtek™ »
https://github.com/OpenSalamander/salam ... ssions/178
I find it easier to write the plugins in C#...
Example plugin that hosts managed WinForms C# .NET application.
PR: https://github.com/OpenSalamander/salamander/pull/177 or branch: https://github.com/KRtkovo-eu-AI/salama ... emo_plugin
2025-09-28 08_12_36-plugins - Open Salamander 5.0 (x64) (Administrator).png (28.14 KiB) Viewed 365184 times
2025-09-28 08_13_04-plugins - Open Salamander 5.0 (x64) (Administrator).png (30.99 KiB) Viewed 365184 times
Example of the usage - Json Viewer plugin: https://github.com/KRtkovo-eu-AI/salama ... nViewerNET (which is refactored this application: https://github.com/KRtkovo-eu/JsonViewe ... Salamander )
2025-09-28 15_37_12-temp - Open Salamander 5.0 (x64) (Administrator).png (29.1 KiB) Viewed 365184 times
2025-09-28 15_37_02-temp - Open Salamander 5.0 (x64) (Administrator).png (37.48 KiB) Viewed 365184 times
2025-09-28 15_37_27-.png (54.08 KiB) Viewed 365184 times
KRtekTM, KRtek™
Open Salamander: Samandarin
https://samandarin.net/
Re: C++ bridge for C# plugins
Nice! Is it compatible with AS 4.0?
Sorry, but I can't see images.
KRtek™
Post by KRtek™ »
The only thing that will block the currently compiled examples is this code which will require Salamander 5.0
https://github.com/KRtkovo-eu-AI/salama ... o.cpp#L108
    // this plugin is made for the latest Salamander version - check it
    if (SalamanderVersion < LAST_VERSION_OF_SALAMANDER)
    { // we block the older versions
        MessageBox(salamander->GetParentWindow(),
                   REQUIRE_LAST_VERSION_OF_SALAMANDER,
                   PluginNameEN, MB_OK | MB_ICONERROR);
        return NULL;
C++ bridge for C# plugins could be used even for 4.0 and older, if plugin is compiled with that version set.
KRtekTM, KRtek™
Thanks.
Sooo, is there an AS 5.0 build with most of the AS 4.0 plugins ready for use? :roll:
KRtek&#8482;
Post by KRtek&#8482; »
AD7 wrote: 03 Oct 2025, 19:06 Thanks.
KRtekTM on Github wrote:In one email I wrote to @janrysavy that I cannot guarantee 100% code quality in the features I started working on (as was shown by the slowdown in application startup after implementing tabbed panels), so I am inclined not to mix the original source code and changes prepared completely using artificial intelligence. That is why I decided to make a fork for brave users - it has bugs and it may take some time to fix them.
It will be called Open Salamander: Samandarin (samandarin is the natural toxin secreted by fire salamander, symbolizing a spicy, daring twist — just like my AI-crafted changes).
It's published: https://github.com/KRtkovo-eu-AI/salama ... ndarin-0.1
KRtekTM, KRtek™
Fine work.
Thanks.
That .PDB files (as jsonviewer.pdb) are not needed? Only for debug?
KRtek&#8482;
Yeah just for debugging, it's possible that I didn't delete all of them when preparing the release (it was a little chaos :lol: ).
KRtekTM, KRtek™
And finally, an important question: Is it for daily use or just for testing? :D
KRtek&#8482;
Open Salamander: Samandarin remains an intentionally experimental fork—its AI-implemented features are actively evolving, may surface unexpected issues, and are best explored by advanced, adventurous users who can tolerate work-in-progress behavior.
But I am using it on daily basis.
KRtekTM, KRtek™
Thanks for clarifying.
BTW. One file (ZIP.SPL) is reported:
https://www.virustotal.com/gui/file/c52 ... 9071c0a091
KRtek&#8482;
ok need to check that, there are no code changes in ZIP plugin.
KRtekTM, KRtek™
KRtek&#8482;
I tried to check the ZIP.SPL compiled from the main (original code from Open Salamander repo) and it's reported too. Unfortunately I don't have another dev environment to run the build (and check if my main computer is infected and therefore infecting other files, OR the issue is in the original code itself).
KRtekTM, KRtek™
