context menu in empty dirs
Guest
Post by Guest »
i`m use tortoiseSVN via context menu with RC2 now.
it would be better if i could access this menu in empty directory useing menu key (which is like Ctrl+M).
ps it would be even better :) if guest forum users type human detect code once per message (for previewing checks, fogotten subj setting...)
Re: context menu in empty dirs
Anonymous wrote:i`m use tortoiseSVN via context menu with RC2 now.
Do you mean enable Shift+F10 in empty directories or when "up dir" is focused?
There is also Alt+Shift+F10 (Opens the context menu for the active panel directory).
