The I may "reuse" this thread
In former Salamander versions it was possible to remove search results by dragging the entry somewhere in the result list. Since RC1 (AFAIR) you now get this STOP sign instead and the 'feature' is gone. I guess this was not the intended use but I found it quite useful to remove some result which I had checked. Just to get a better overview about the results, esprecially when there where many hits.
Any chance to get a "remove from search results" feature back? Thx!
Could you please specify how to "remove from search results" in older versions of Salamander? I'm not able to reproduce it (tested on version 2.5 Beta 11).
