Guest
Post
by Guest » 02 Nov 2006, 23:10
Hello anybody,
a little question:
Why RC2 don't remeber on which Screen is it closed.
Salamander starts only on Primary Screen.
Is there a solution, where i can configure on which Screen Salamander starts ?
Thanks for help
Posts: 5232 Joined: 08 Dec 2005, 06:34
Post
by Jan Rysavy » 03 Nov 2006, 08:23
Hello, please look at Options > General > Save configuration on exit. Is it checked?
Guest
Post
by Guest » 03 Nov 2006, 18:21
Thanks
I don't want to save the setting each time, but I saved the configuration once, when salamander is shown on second monitor. That's it.
Post
by Jan Rysavy » 03 Nov 2006, 20:04
What options would you like to see instead of current "Save configuration on exit"?
-Save windows position
Something else?
Guest
Post
by Guest » 03 Nov 2006, 22:30
An option which i can check that window position will be saved on exit, but all other configuration in the registry should be untouched.
