using ZIP Plugin with files > 2GB
hhk99
Post by hhk99 »
Hello,
I just encounterd a problem with the zip plugin.
After unpacking a file previously compressed with the zip plugin, I get differen md5sums:
cc05ef41201b9827ef0216a55ab11e9c komplett (original)
size = 2,626,263,040 bytes
82219f0d38896e7d1566f2b036ec7430 komplett.zip
size = 255,589,217 bytes
7b2aaa103279ad454fee8022b29e36e2 komplett (after unzip wiht the plugin)
Using gzip on a linux os, everything is ok
gretings
hans-hermann
Hello, unfortunately I cannot reproduce this problem (tested on file with size 2 756 655 104 bytes).
Is it possible you have some problem with your hard drive or controller?
Please try to unpack archive again and compare both unpacked (bad) versions.
