Hello,
It would be nice to be able to configure the filename extensions, that the tar plugin will use to extract and compress archives.
This would be very helpful for java archives (*.jar, *.war, *.ear etc), which use the tar format...
						TAR Plugin file extensions
Re: TAR Plugin file extensions
Java archives do not use tar format (also *.jar should not work via TAR plugin), instead they (*.jar defaultly) are browsable by ZIP plugin. You can easily extend this in Configuration -> Archivers -> Archive Associations in Panel by other java archive-like extensions (sar/war/ear).abellmann wrote: This would be very helpful for java archives (*.jar, *.war, *.ear etc), which use the tar format...
