Copying directories without files
mailyourmom
Post by mailyourmom »
Would it be possible to include an option in Servant Salamander's Copy
dialog to copy only the directory structure without any files? That would
be very convenient.
Thanks!
1. Select the desired directories
2. Press F5 (Files > Copy command)
3. Click Options to expand dialog box
4. Set Files named option to |*
5. Click the OK button to start operation
:idea: Click the masks hints to display more information about masks.
mailyourmom
It works!
Tried and tested. Many thanks.
Moderator: Moved from Feature Requests.
