Unique features you use the most?
I use quick search/incremental search hundreds of times a day and especially the wildcard search with the slash. Having used salamander for years I have come to appreciate utilitarianism of the salamander when compared to its peers which I have also used over the years. The intuitive and remarkably well fleshed out user interface is truly a masterpiece in software design. Thank you developer(s)!
Re: Unique features you use the most?
My favorite feature is the plugin PictView with the function select and cut.
That's the reason because I have suggested the option "Undo (STRG+Z)" and "Redo (STRG-Y)" for this plugin.
