If a process uses a directory you can't delete it, and the ServSal aborts the operation.
Any chance of a "show me what's locking the directory" feature in those situations?
It's a lot of trouble identifying these processes and a feature like this would gives us a chance to detect unautorized programs og clean up bad uninstallations.
- and it's something the clones like "Total Commander" ant others doesn't have.
Delete directories in use
Hi hrc,
for such issues is Unlocker good for.
You find it under http://ccollomb.free.fr/unlocker/ (~ 200kB)
If you wanna carring Unlocker with you on your USB-Stick
you can copy the install folder to your Salamander folder.
Bevor using this tool you have to register one DLL.
You can do this with an simple batch file too:
Save this as _STARTME.cmd into your Unlocker folder.
Then use Unlocker by executing _STARTME.cmd
Use your User menu for to apply an button for this command.
HTH
Edit:
Aaaa, one thing to be proper on others PC,
use this batch to de-register this DLL bevor you wanna leave the PC
_STOPME.cmd
Edit 2:
if one prefer to have both in one batch file, use this as "_STARTME.cmd" :
Use "_STARTME.cmd" to start
Use "_STARTME.cmd stop" to stop
@ECHO OFF
REM to use Unlocker without installation, just register this DLL, Stefan.
::registering the DLL, /S means be silent
regsvr32.exe /S UnlockerCOM.dll
::and now start Unlocker for me. I will find it then in my context menu.
Unlocker.exe
HTH
Edit:
_STOPME.cmd
@ECHO OFF
:: and after you are finished and leave an PC of e.g. your friend,
:: you may wanna clean off your tracks by
:: de-registering the DLL, /S means be silent
regsvr32.exe /S /U UnlockerCOM.dll
Edit 2:
@ECHO OFF
IF "%1"=="stop" GOTO _de-register
IF "%1"=="s" GOTO _de-register
::and now start Unlocker for me. You will find it in your context menu.
Unlocker.exe
GOTO _END
:_de-register the DLL again with "_STARTME.cmd stop"
@ECHO OFF
:_ENDUse "_STARTME.cmd stop" to stop
AbteriX
