Separation of FTP connect dialog and bookmarks
In the FTP connect dialog, when it pops up, the last bookmark used is selected. If I want to connect to a new location I must remember to first select the 'Quick Connect' entry, because else there is no way (or is there?) to keep the settings of the bookmark as they were before I started to enter new connection details. In my oppinion, this is inacceptable behaviour (and contrary to generaly accepted design rules, yes even against German law). There needs to be a way to undo the changes before they are committed in some way. Therefore there should definitely be a 'Save' button and either a 'Name' field or a 'Save as' button. No Bookmarks should be auto saved, unless you add a recent connections feature, which might be more useful than the current field histories on 'Address' and 'Initial path' fields.
