my company network drives no longer show (upgraded to Windows 10)
MaxMMM
Post by MaxMMM »
This is my issue:
Since an upgrade to Windows 10 yesterday I do not get the Company Network drives when I am on VPN Connection.
The Windows own Explorer gets everything, but Salamander does not....
any clue what I could do or check?
Please help.
thank you very much and best regards
max
Re: my company network drives no longer show (upgraded to Windows 10)
Do you run Altap Salamander as Administrator? See main window title, there would be (Administrator) text.
MaxMMM
Post by MaxMMM »
Yes I do.
MaxMMM
Post by MaxMMM »
ok, now I get my drives.... thank you!
Still, I am curious, because I originally chose to execute as admin because in an earlier Version of WIN I had the exact same issue with network drives but running as Administrator it stopped, now it is exactly the other way round----
Can you explain why that is?
You can find an explanation for why this happens at https://support.microsoft.com/en-us/kb/3035277.
The remedy given there might, or might not work in your case, depending on how your VPN software interacts with your system.
MaxMMM
Post by MaxMMM »
Thank you very much. Will confront our IT Department, in fact VPN Client changed to a newer one, maybe Settings are not in favour of running Altap in admin role...
