Is there a way to remove only periods that are NOT surrounded by digits?
For example...
Servant.Salamander.2.5.Rocks
to
Servant Salamander 2.5 Rocks
Using the batch renamer???
Batch Renamer: Remove only periods from file names
Yes, it is possible.
Turn on Regular expression, set Search for to
(?<=\D)\.|\.(?=\D)
and Replace with to space (or other character, for example underline).
Zero-width positive lookahead assertion is used...
http://www.regular-expressions.info/lookaround.html
(?<=\D)\.|\.(?=\D)
