Most of the time I try to avoid floating windows.
Please enable a command (hotkey and button, also) to display PictView output (and the output of the other viewers) embedded in the "opposite" panel from the selected file.
Also, enable a setting to capture/restore the divider position when the viewer is displayed in the opposite panel.
Thanks!
REQST: Choice to display viewers in opposite panel
Mouse-centric, Registered
Re: REQST: Choice to display viewers in opposite panel
Nice ideaJohnFredC wrote:Please enable a command (hotkey and button, also) to display PictView output (and the output of the other viewers) embedded in the "opposite" panel from the selected file.
Kind regards, KNUT
Guest
I too would love this.JohnFredC wrote: Please enable a command (hotkey and button, also) to display PictView output (and the output of the other viewers) embedded in the "opposite" panel from the selected file.
Yes, please
Use the other panel as preview
http://forum.altap.cz/viewtopic.php?t=172
Jan wrote:
> We call it Quick view in ALTAP Roadmap.
Quickview Panel
http://forum.altap.cz/viewtopic.php?t=42
Quickview Panel
Stefan
Pleased user since v1.52 - Licence# 0306-0046-01
