Is it possible to purge cluster slack space using the Encrypt/Decrypt plugin.
Cluster slack space is the space between the end of file and the end of the last allocated cluster.
Does Clean Disk Free Space do this already or could it be added.
Would anyone else be interested in this?
For this feature it aslo was good to have the option to fill the space with a particular byte (or pattern). This would help in getting smaller disk images with some compressing disk imagers.
Shred cluster slack space
