x64 support
Guest
x64 support
Post by Guest »
Hi
I think you should provide 64-bit build of SS as soon as possible: 32-bit file managers cannot work with 64-bit system32 directory.
It would take a real advantage over TC as TC is written in Delphi and therefore still doomed to be 32-bit.
Josip Tosic
Post by Josip Tosic »
This one gets my vote too.
I've been using Total Commander since V1.12 and, well, switched to x64 and tried installing XviD... Took me half an hour to figure out why my codec wasn't appearing in VirtualDub.
I've googled some and this post introduced me to Servant Salamander. Or rather, reintroduced; I did try it a long time ago but the lack of queues turned me away.
Guest
Post by Guest »
Please oh please :) add support for shell integration for Windows x64.
That is I mean, for example, while using standard windows explorer there are shell extensions for WinRAR to make/extract/... an archive, these options are available ar right-click of a mouse. But when using Servant Salamander, there are no these right-click options for me to work with WinRAR.
Please add support for shell extensions. Please :)
Thank you :)
