								zxmar05
		Posts:  4  		Joined:  03 May 2006, 15:44
						Post
								by zxmar05   »  03 May 2006, 16:17
			I'm using the 'Hot Paths' bar as a poor mans tabbed interface. One problem I have is that long file names take up a lot of place on the 'Hot Paths' bar, limiting the number of visible entries.
I propose an option to limit the display width of entries in the 'Hot Paths' bar.
Regards,
Eduard
								JohnFredC
		Posts:  162  		Joined:  10 Dec 2005, 15:44
						Post
								by JohnFredC   »  03 May 2006, 16:36
			Perhaps Salamander should have a user customizable  "alias" value for each path to display instead of the path itself .
							Mouse-centric, Registered
		Posts:  5231  		Joined:  08 Dec 2005, 06:34
						Post
								by Jan Rysavy   »  03 May 2006, 16:47
			Options > Configuration > Hot Paths
Change the Hot Path name in Defined Hot Paths  list.
								JohnFredC
						Post
								by JohnFredC   »  03 May 2006, 16:54
			Well duh!
Of course!
								zxmar05
						Post
								by zxmar05   »  04 May 2006, 13:59
			Yes, that works. Great!
