lost registration-keys
schenke
Post by schenke »
hello,
cause of a hdd-crash i lost the file with my ss registration-keys. which files i need to extract from ss-directory to rescue this information?
thanks
jis
Re: lost registration-keys
Post by jis »
salamand.key
schenke
Post by schenke »
ok, thanks. i also exported pictview.key from plugins/pictview directory. on purchase i got a zip-file. in which way these 2 files are stored in there? only in simple directories?
jis
Post by jis »
schenke wrote:ok, thanks. i also exported pictview.key from plugins/pictview directory. on purchase i got a zip-file. in which way these 2 files are stored in there? only in simple directories?
Oh, you didn't say exactly what keys you lost. So, originally the keys are saved in zip file like this:
#  Archive F:\Install\Applications\File Managers\Servant Salamander\keys.zip
2001-03-27 19:42        Folder        Folder  plugins
2001-03-27 19:42        Folder        Folder  plugins\pictview
2001-03-27 19:42           911           911  plugins\pictview\pictview.key
2001-03-27 19:42           919           919  salamand.key
# Total                   Size        Packed  Files
#                         1830          1830  4
After installing Servant Salamander you just do import registration keys from help menu...
schenke
Post by schenke »
ok, thats it!!
thanks a lot. this works!
jis
Post by jis »
You are welcome, it was only small help in your situation after HDD crash. I wish you quick recovery from that.
You can send us email (include some identification data such as name and address) at support@altap.cz and we will send you back your registration keys.
