Some files are not shown correct in the viewer. All chars are shown in a vertical line.
Is this a codepage/coding problem?
Viewer doesn't show text files correct
Tomas Kopal
Re: Viewer doesn't show text files correct
Can you verify that the file is not Unicode encoded? (e.g. switch to hex-view and check if every letter is not followed by a zero).Eric wrote:Some files are not shown correct in the viewer. All chars are shown in a vertical line.
Internal viewer does not support Unicode texts yet.
Eric
It's an unicode file. Are there any plans to support Unicode? I thinks it's a important feature.Tomas Kopal wrote:Can you verify that the file is not Unicode encoded? (e.g. switch to hex-view and check if every letter is not followed by a zero).
Thanks
Eric
You are not alone.Eric wrote:It's an unicode file. Are there any plans to support Unicode? I thinks it's a important feature.
1) Try to Search "unicode" - Search found 21 matches including your post.
2) Here is ALTAP Roadmap for next Servant Salamander versions:
http://www.altap.cz/salam_en/newver.html
- Unicode support, UTF-8,16,32 (names in panel, viewers, find, convert, compare).
I use Lister32 from Mr. Ghisler for unicode files.
I have made a new *.reg entry in the viewer options (above of the *.*)
and assigne this to Lister.exe
I have also an new entry in the alternative viwer list as *.*
with Lister.exe.
You can reach this alternate viewer by pressing Ctrl+Shift+F3
So i have there view64.exe and ListXP.exe too.
You can do the same for Ctrl+Shift+F4
with Lister.exe.
Stefan
Pleased user since v1.52 - Licence# 0306-0046-01
Klettermaxe
Alternate viewer for unicode-files
This is a very useful tip.Stefan wrote:I use Lister32 from Mr. Ghisler for unicode files.
