I have two instances of SS installed (laptop and desktop). If I add new file to the RAR archive on my laptop, operation executed in-place (in-panel?).
When I perform the same operation on my desktop SS starts a new window (DOS prompt) and tries to execute it there. How can I enforce "laptop" behavior on my desktop SS?
Thanks,
Dima
RAR re-packing executed in the external program
How are you adding the file to the archive? Using the pack dialog, or copying to a pannel with the opened archive?
Dependent on how you do it, different configuration options do apply.
I hardly ever use the pannel mode. With an external packer launched from the pack dialog, the packer starts in a minimized console window in the background. After some while, if the operation takes longer, the minimised background window pops to the front.
Could you verify whether you get these windows on both computers, please.
Furthermore you say '... tries to execute it there.' Does it try and succeed or try and fail?
