Guest wrote:This doesn't help you but..
I think the issue is with VideoRedo. I was 'Ad removing' one of my recorded shows when VideoRedo crashed. It deleted all my 'video' files (.mpg, .rec, .ts) from a number of folders that it previously had access and no other program was running at the time.
Using a number of recovery utilities could not locate most (any) of the files.
not a happy camper!
Did you report this problem to VideoRedo authors?Anonymous wrote:what I found tonight was a version I downloaded from a usenet forum deleted everything in each folder that I was working on. Everything was fine until I hit the close X and then I noticed the folder showed no more files.
I doubt they read this forum
