Is there any way to set the default in the Find Files and directories
I generally want to limit my search for context to last 3 months and search in *.txt,*.csv & *.xls files.
Find Files and Directories - default settings
Re: Find Files and Directories
Via Options -> Manage (in the Find dialog) you can save search settings and then set one of them as default.
magentalinas
Re: Find Files and Directories - default settings
Thanks. I never though of looking there. Makes life easier.
