Mobile Media Access
vld
Mobile Media Access
Post by vld »
I decided to give v3.02 a test drive after I could not see my new Samsung Note 3 mobile phone via AS254. I still cannot see it with AS302 but I have no problem seeing it with Windows Explorer? Is there a trick or is this impossible with v3.02?
Re: Mobile Media Access
Hi vld,
have you used search on this forum?
Basically, you have two options. If your device/OS support it, turn your device into mass storage mode.
Or else, search for a suitable total commander plugin and install it using AS's proxy plugin.
vld
Post by vld »
Windows explorer detects it without a problem. But it cannot be seen with Salamander.
vld
Post by vld »
Thank you Jan
