Hello.
Withe the current version of Salamander, the program is not showing or listing the following folders:
C:\ProgramData
C:\User\AppData
Do i have a setting incorrect somewhere??
Missing ProgramData and AppData folders
- programdata2.jpg (21.03 KiB) Viewed 15766 times
- programdata1.jpg (13.36 KiB) Viewed 15766 times
Re: Missing ProgramData and AppData folders
Look at following switch: Options > Configuration > Panels > Hide files and directories with hidden or system attribute (Ctrl+H) - is it cleared?
Don't know how i missed that setting...........must have accidentally toggled it.
Issue Fixed.
Thanks.
Issue Fixed.
Thanks.
You might have accidentally pressed the hotkey Ctrl+H
But there's a visible hint in the Directory Line: The filter symbol only appears if any files or folders exist but are not displayed.
Note: The symbol is also used with the file mask based filter (Ctrl+F12)
Thank you so much!
In German version this is: Optionen - Dateifenster: Dateien mit Versteckt...Attribut ausblenden
It took me some 30 Minutes of searching to find this entry in Forum. Makes my evening!
