AS 3.01 + Eroiica Viewer WMF Error 80004005
blee
Post by blee »
I just upgraded to Altap Salamander 3.01 (x86) and Eroiica Viewer no longer function.
I get error msg:
Creating instance of WMF export filter failed. (80004005) Unspecified error
and:
Eroiica Viewer plugin has not been loaded. Plugin is not valid Altap Salamander Plugin or some plugin internal error has occured.
I tried downgrading to AS 3.0, but I am still getting this error message. Everything was working fine on AS 3.0 before I upgraded to AS 3.01.
Re: AS 3.01 + Eroiica Viewer WMF Error 80004005
I saw the same problem today while upgrading from AS 3.0 to AS 3.01. In my case the problem was gone after restarting Salamander.
What Windows version do you use? I'm on Windows 7 x64 Pro.
It looks like an old problem: http://forum.altap.cz/viewtopic.php?f=2&t=2020 and http://forum.altap.cz/viewtopic.php?f=16&t=6176
Message on Czech Windows:
Eroiica Viewer
(80004005) Nespecifikovaná chyba
[OK]
Blee,
can you please send us a "bug report"?
1) After having seen the error, launch another instance of AS
2) In the new instance, go to "Help/Task List..." menu entry
3) Select the original instance in the "Altap Salamander Task List" dialog
4) Click the "Break" button
5) Send us the bug report.
Thanks in advance,
-- Jan
blee wrote:I get error msg:
blee
Post by blee »
Okay, sent bug report. Let me know if you didn't receive it.
Thank you, we received it.
Fixed version of Eroiica Viewer will be released with Altap Salamander 3.02. Thank you for help.
