No mouse scroll on change drive drop down.
My mouse scroll wheel does not work on the change drive drop down (ok, I have a ~lot~ of mapped drives). It works everywhere else in SS.
Re: No mouse scroll on change drive drop down.
I think that this is feature request rather then bug.WillM wrote:My mouse scroll wheel does not work on the change drive drop down (ok, I have a ~lot~ of mapped drives). It works everywhere else in SS.
One question: When you scroll with the wheel to the needed drive - How you will activate that drive?
Re: Feature / Bug: I figured that any list that is longer than available space should be scrollable without having to go to the up / down arrows and then move back to your desired selection.jis wrote:I think that this is feature request rather then bug.WillM wrote:My mouse scroll wheel does not work on the change drive drop down (ok, I have a ~lot~ of mapped drives). It works everywhere else in SS.
Re: Activate - Well eventually you have to highlight it and left-click. But that is kind of obvious - is that what you meant by your question?
Of course, if both your hands are on the keybaord, then [Alt-F2]-[/] is the quickest way (thank you for that shortcut).
Will
