IContextMenu::InvokeCommand in a separate thread
- crystalidea
When downloading an .exe (some setup of some app) and running it first time, after starting in Salamander (Windows Explorer) Windows verifies the digital signature, and this verification can take up to 10 seconds (before the actual process will start), during which Salamander simply hangs. Is there a way of improving that?
Thanks
Thanks
Re: CreateProcess in a separate thread
+1
I have encountered such long hangs too.
But it usually helps me when I delete the Zone.Identifier ADS of the downloaded exe-file 1st ([ZoneTransfer] ZoneId=3), before I start it.
Yeah, this is especially noticeable with large files (> ~20 MB).
I believe it's not CreateProcess, but ShellExecute(Ex).
Similar, maybe related, slow-downs:
- when an icon is being read from the file
- when the file is being checked by an anti-virus
- when opening a file in WMP for the first time -- the configuration wizard blocks Salamander
- when the opened application requests elevation
- crystalidea
Salamander uses CreateProcess
ShellExecute uses CreateProcess as well
Salamander is using IContextMenu::InvokeCommand method with default context menu item (for executed file).
- crystalidea
thanks for the info, anyway, what about this improvement?
It is interesting idea...
- crystalidea
Sure, all my ideas are worth their weight in gold
- crystalidea
Sometimes it really hangs for 10 seconds, just counted
- crystalidea
itunes64setup.exe is a good example of very long delay
- crystalidea
Please, please, please fix this annoying bug.
Isn't it possible to disable this feature in Windows settings?
Running context menu invoke in different thread is not simple with existing Salamander open handler. Actually it is nearly impossible.
- crystalidea
I don't want to disable digital signature checking (and doubt it's really possible).
Ok, then why not to run IContextMenu::InvokeCommand in a separate (non UI) thread?
As I said before, it is not easy with open handler we have.
We can consider it if there will be more requests.
- crystalidea
there won't be any more request for that, most Windows users get used to such crazy things in Windows Explorer.
I do think it's an important usability improvement, threads are our friends
