New Close All (Alt+Shift+F4) command?
From http://forum.altap.cz/viewtopic.php?p=26343#p26343
Ether wrote:I sometimes end up with several used and unneeded Find windows
Note: I have the same problem with other windows too (typically PictView or Internal Viewer). We should consider additional window menu command Close All (Alt+Shift+F4) that would close all windows of its kind (find windows, viewer windows, ...).
Re: New Close All (Alt+Shift+F4) command?
Belonging to the same instance of as? or belonging to any? I always have several AS instances running (mostly due to the lack of some bookmarking functionality). With the mess Windows taskbar creates with my task buttons, I'd newer know which belongs to which.
fraktik
Post by fraktik »
+1
I would like to have this too - and in preferencies you can decide, if "for all instances" (and "which types together" maybee too)!
