Sorry if I'm repeating issue report, but I didn't find similar one.
Context menus miss items, present in windows explorer. Just simple as that... See the pictures, attached to this post.
I've tested version 2.54 on Windows 7 Professional 32bit, Windows 7 Enterprise 64 bit, Windows 7 Home. On all of them I have this problem.
Partial context menu
alexvinchev
- Context_Salamander.jpg (61.34 KiB) Viewed 17545 times
- Context_Windows_Explorer.jpg (97.14 KiB) Viewed 17545 times
Re: Partial context menu
Could you please also test Altap Salamander 3.0 Beta 2?
How do you open the context menu? Just mouse right-click? No modification keys on keyboard?
alexvinchev
I'm always opening it with right click, no KBD buttons...
In AS x64 Beta 2 it looks much better...
- CMAS.jpg (66.92 KiB) Viewed 17538 times
- CMWE.jpg (96.96 KiB) Viewed 17538 times
Salamander 3.0 seems better than Windows Explorer which is clipping several icons.
Isn't that going to be a 32/64-bit shell context-menu issues.
(What a farce 64-bit is, at least for me, & in most circumstances!)
It looks so, but what was strange:
alexvinchev wrote:I've tested version 2.54 on Windows 7 Professional 32bit, Windows 7 Enterprise 64 bit, Windows 7 Home. On all of them I have this problem.
alexvinchev
I've re-tested on Win7 32-bit, you're that it is OK there, just order of the menu is different (vs Win 7 64 bit).
When are you going to release officially 3.0?
We are going to release another testing version soon with a new copy engine (Windows Explorer speed for copy operations over network). We also need to implement UAC support. Then we can release the final version 3.0.
