Invalid Hot Path in Windows 7
DavidDe
Post by DavidDe »
Hi all,
I have Salamander 2.54 installed on Windows 7. I am attempting to set a hot path for Desktop folder but Salamander does not accept the folder path when pressing Control+Shift+[digit]. When attempting to copy and paste the path C:\users\myname\desktop manually in the hot paths list Salamander shows message that the hot path is not valid.
Please advise me for this
TY
Re: Invalid Hot Path in Windows 7
Are you entering the path into the Path field under the list? The list itself shows labels, not necessarily paths.
DavidDe
Post by DavidDe »
The path field is disabled for empty hot path list items.
Anyway my problem is now solved. The "Control+Shift+Number" worked only after I tried to assigned the hot path by right-clicking the window caption bar and selecting Assign Hot Path option from the context menu. It may be a bug.
TY
If you can reproduce described problem, please show screenshot of Options > Configuration > Hot Paths window and message about invalid path.
DavidDe
Post by DavidDe »
I am attempting to reproduce the problem, but it seems I have to reinstall Salamander to again face with it, perhaps. I will provide you with snapshots if the problem comes back.
TY
