Hello.
Please add an option to export registry keys into the clipboard.
Export from registry plugin
Half-Death
- reg export dialog proposal
- salamander_reg_export.jpg (12.27 KiB) Viewed 11892 times
Re: Export from registry plugin
What would you expect to be in the clipboard after the operation? The same text content that was otherwise in the file? with or without header and BOM? What is the purpose of this?
I would think that this could help with creating custom .reg files. For example export various parts one by one to the clipboard and paste them into the resulting file.
Half-Death
Yes, the same as it were in a file.SvA wrote:The same text content that was otherwise in the file? with or without header and BOM?
There are situations when I don't need the file, but the text only. Now I have to go to the file and copy the text manually and then delete the file.SvA wrote:What is the purpose of this?
