GZ File Decompression
jcgriff2
Post by jcgriff2 »
Hi -
,gz files are not decompressing fully; no error messages.
GZ files are ~45 MB
Uncompressed ~400 MB
I'm getting partial un-GZ files ~ 15 MB with PB87.
I am able to un-GZ the files with other 3rd party apps, but don't like that option. :)
Thank you. . .
John
J. C. Griffith
Microsoft MVP
Windows Expert - IT Pro
Slanec
Re: GZ File Decompression
Post by Slanec »
I think that the devs won't really be able to help without any additional information about the file (any special attributes, characteristics, the tool the file was created with, or the file itself).
Hi John, Are you able to provide us such GZ sample?
jcgriff2
Post by jcgriff2 »
Hi Jan. . .
I will be glad to provide access to the GZ files; however the info is of a sensative nature.
I'll send the info to you privately.
My apologies, as I know doing so defeats the purpose of public forums, but no alternative in this case.
Regards. . .
John
J. C. Griffith
Microsoft MVP
Not a problem, thank you. We will keep your files private and destroy it.
Tomas Kopal
Post by Tomas Kopal »
Thank you for your help, the problem should be fixed in next Salamander version. Please re-test and let us know.
