Hi
I prefere using Irfan View over the pictview plugin. Since it supports many extensions, several entries in the configuration's Viewer setup list are required. This, however, leads to multiple entries of this viewer in the popup menu activated by SHIFT-CTRL-F3.
I have still got a version 1.6 beta 5 of Servant Salamander running. There this problem does not appear.
(this is a minor nuisance, not really a bug or problem)
Custom viewer in SHIFT-CTRL-F3 popup menu
Re: Custom viewer in SHIFT-CTRL-F3 popup menu
Stefan, many thanks for reporting this. I also recognized this some time ago.Stefan von Allmen wrote:(this is a minor nuisance, not really a bug or problem)
Kind regards, KNUT
Interesting, I have never had this problem and I use Ctrl-Shift-F3 quite often...KNUT wrote:Stefan, many thanks for reporting this. I also recognized this some time ago.Stefan von Allmen wrote:(this is a minor nuisance, not really a bug or problem)
It only appears for external viewers, the plugin viewers are "merged" correctly.Jan Patera wrote:Interesting, I have never had this problem and I use Ctrl-Shift-F3 quite often...
