Problem with switching interface language
I have changed the language from English to Romanian. It worked ok. Then I tried to move back to English, but it didn't work, after restart the interface was still in Romanian. Repeated several times, then I edited directly in registry. I am running Salamander on Windows 7 Ultimate.
Re: Problem with switching interface language
Did you save the configuration? Do you have the Save configuration on exit setting enabled?
