If Altap Salamander would shred files as a background process it would improve my productivity. As it stands, I have to open a second instance to continue working while files are shredded.
Thanks!
Shred files in the background
Re: Shred files in the background
This is also true for (un)Packing, (en/de)Crypting, Undeleting...
Hell, the "only" function in Salamander that supports inBackground (and Queueing!) is Copy/Move.
It is on the developers' TODO. For like ten years. After the Salamander code is migrated to VS2010, enriched with Unicode support, UAC support, after x64 version is released, thed hopefully we'll get queued processes running in background. And tabs. So, in, like, another ten years
Be patient. Or just get used to run many instances of Salamander as it is the current official way. And because of Salamanders VERY low memory footprint, it shouldn't be a technical problem. Yes, it could be more comfortable...
In the mean time use your 2nd instance to work as a workaround
Opening a 2nd one won't eat up alot of memory and only takes a few seconds to start up so i don't see u huge increase in productivity. UAC, Unicode, X64 are more urgent
True. Just a wish.omega wrote:In the mean time use your 2nd instance to work as a workaroundOpening a 2nd one won't eat up alot of memory and only takes a few seconds to start up so i don't see u huge increase in productivity. UAC, Unicode, X64 are more urgent
That's true. However I hope the development of new features will not be stopped after implementing this three most requesting features.omega wrote:UAC, Unicode, X64 are more urgent
Therefor it its important to keep users reporting bugs (if any) and requests for new functionality which should be added on the wish list.
Ofcourse development will not be stopped and more great feature requests should continue to be made. That's why i said in the mean time he will just have to use 2 instances while urgent things have higher priority.
