Start Program in Salamander Issue
Normally, I can either type <enter> or double-click on a program that is listed in either pane of Salamander, and this will start the program. At present, however, this is not working (instead, to achieve the same result, I have to right click and choose "Open"). However, this same function (and, by the same means, that of either typing <enter> or by double-clicking) is still working in Windows Explorer. I then installed Salamander again (though I did not first uninstall it), but this did not resolve this issue. I don't recall running into this problem before, but would be grateful for any help. Thanks.
Re: Start Program in Salamander Issue
JimC,
can you check behavior in MS Explorer? Is it working as expected or same as in Salamander?
What kind of file is it? What extension? Maybe it's a registered extension in Archives Associations in Panels?
Just a wild guess...
Try using ShellExView to locate problematic shell extensions and see if disabling them helps. You can also post the list here.
It's mentioned in the original post.ino wrote:can you check behavior in MS Explorer?
Ether wrote:It's mentioned in the original post.ino wrote:can you check behavior in MS Explorer?
Yes, the issue only occurs in Salamander, not in MS Explorer.ino wrote:Ether wrote:It's mentioned in the original post.ino wrote:can you check behavior in MS Explorer?
The problem occurs in the case of any "run-able" file, with any *.extension name (e.g., *.exe, *.pdf, *.bat, *.doc). (via single-click, I can "look inside" zip files OK; that is not a problem). The problem is simply that any file/accompanying program of any extension name that would normally "start up" in AS via either <enter> or double-click, now, will not start by either of these methods; instead, any and all such files will only "load" via right-click, select <open>.mdruiter wrote:What kind of file is it? What extension? Maybe it's a registered extension in Archives Associations in Panels?
I have attached my ShellExView list of extensions. What is the best way to go about determining where the problem lies? I see that none of my extensions are disabled <g>; perhaps that will explain why I have about a two-second delay, upon right-clicking, before my extensions list appears. I'm glad to disable all non-essentials; any advice here, too, will be welcome (I've attached my ShellEx extensions list, as PDF).Ether wrote:<span>Try using [url=<a href="http://www.nirsoft.net/utils/shexview.html]ShellExView[/url]" class="smarterwiki-linkify">http://www.nirsoft.net/utils/shexview.html]ShellExView[/url]</a> to locate problematic shell extensions and see if disabling them helps. You can also post the list here.
Thanks.
- JimC-Shell Extensions List.pdf
- (138.31 KiB) Downloaded 1097 times
OK, I uninstalled AS, and deleted my old Configuration from registry upon reinstalling AS. Then, with the AS default configuration loaded, both double-clicking and typing <enter>, once again, worked properly, for the purpose of starting up files/programs as usual.
I saved out the default (i.e., AS-initially-provided), good-but-vanilla Configuration to a file in case I should need it later. I then reinstalled my old Configuration into AS (renaming it to "config.reg" for this purpose), which was then re-inserted into the registry when I exited AS.
Then, upon loading-in my old personal Configuration, my problem concerning the non-functionality of double-click and <enter> returned. So it seems conclusive that the problem here is in my old (presumably corrupted) Configuration file.
Since I, however, have many carefully-crafted "good" settings in this Configuration file--ones which I very much wish to restore into AS with as much ease as is possible--I would like to use this file as it is--except for, of course, removing whatever the corrupt section therein may be. Then, hopefully, the above-mentioned "double-click and <enter>" AS functionality may be restored--without losing all my custom settings in the process.
I have attached my (apparently) corrupted Configuration file, zipped, as "JimC Problem config_.zip", hoping that one of you can advise me as to what section of this Configuration file is causing the problem.
Thanks.
Thanks.
- JimC Problem config_.zip
- (33.83 KiB) Downloaded 636 times
Unfortunately, the PDF file seems to display a fraction of the contained information, rest is outside the page. CSV should be better.
Also, I installed your configuration file and I can run and open files with no problems, so it seems the issue is caused by a combination of factors. I'll try to dig more into it, but I doubt I'll see anything interesting. Meanwhile, you can try to delete the live configuration, let it regenerate and then restore the old one piece by piece (the Registry plugin is good for that) and see what piece is causing all this. You may encounter some other quirks with Viewer and Unpacker associations though, because of the way Salamander references plugins in its configuration.
Ditto.I installed your configuration file and I can run and open files with no problems
Perhaps start out with a new setup.
Cut your .reg file in half, & merge that into the registry.
Start Salamander & test.
If that bombs, do it again, but cutting that half in half.
If it works, then concentrate on the other half ...
(I really like your 'Selected' highlighting. Going to have to look through & see how you did that. And I thought I was the only one left using Eudora
