Find, hide and position
mdruiter
Post by mdruiter »
The cursor position in Find is strange after hiding files.
I try:
- search for (find) a long list of files and folders
- go to position 20 or so
- select that file and up (Shift-Ctrl-Home)
- hide (Ctrl-H); the first file (of folder) is selected afterwards (position 1)
- press Shift-Down (or Shift-PgDn)
The selection seems to start at position 20 now, which is strange. If I press Down, Up first and then start using Shift, everything works like expected.
If after hiding less than 20 files and folders exist, the selection starts at position 2 after Shift-Down.
This has been true for quite some versions of Salamander.
I tried to look for similar postings, but searching for Find returned nothing at all!?
Groente, Michel.
k0nelupy
Post by k0nelupy »
As far as I know this problem hasn't been reported before on this forum.
By the way: this is how problem reports should look like ;) Nice and easy list of steps to reproduce the problem. Good work!
mdruiter
Post by mdruiter »
I'm a developer myself...
But I'm curious whether anyone can confirm the problem.
Groente, Michel.
mdruiter
Re: Find, hide and position
Post by mdruiter »
I still have the issue, using version 2.52 :(
Groente, Michel.
mdruiter
Post by mdruiter »
Also in 2.53 PB38. :|
Is it hard to fix?
Re:
mdruiter wrote:But I'm curious whether anyone can confirm the problem.
I can confirm. I think the fix is a simple matter of moving the "selection start position" to the resulting (first in this case) position in the list as well, similarly to the focus.
Fixed, will be available in next release of AS.
mdruiter
Post by mdruiter »
Confirmed, hurray! :D
mdruiter
Post by mdruiter »
I'm sorry to say that not all situations are fixed. The exact situation I described in the starting post is not fixed. :(
I tried the 2.53 release.
Confirmed. Unfortunately I didn't find how to solve this problem. Looks like common controls / listview bug to me.
Fixed with small hack!
ListView_SetItemCount(FoundFilesListView->HWindow, 0); // hack
ListView_SetItemCount(FoundFilesListView->HWindow, totalCount - deletedCount);
mdruiter
Post by mdruiter »
Great, works as it should now!
