Remember Find position on Hide
mdruiter
Post by mdruiter »
I find it cumbersome that the cursor jumps to the top of the list if I press Ctrl+H (Hide) in the list of found files and directories (Find). Especially in long lists, which I happen to use often.
Is it very hard to put the cursor where it was? Or, at least, just above the first hidden object. Or... anything but jumping to the top!
See also http://forum.altap.cz/viewtopic.php?f=2&t=3112
Re: Remember Find position on Hide
I will look at this issue and let you know.
mdruiter
Post by mdruiter »
Thanks in advance!
I noticed that on Delete, the cursor does stay where it was.
Fixed, will be available in next release of AS.
mdruiter
Post by mdruiter »
I can't find the words to express how grateful I am that this is fixed. :D
Every time I press Ctrl+H, I'm positively surprised that the cursor stays where it is!
:D
