Tool Bar Icons are to small
Jorrick
Post by Jorrick »
icon example.jpg (226.92 KiB) Viewed 25028 times
KNUT
Re: Tool Bar Icons are to small
Post by KNUT »
The icons are perfect for me!
Kind regards, KNUT
No problem with the icons here either.
Is it the size or the spacing between the icons that you're having trouble with?
You can add "Separator(s)" which will slightly widen the spacing (in addition to adding the separator bar).
(Maybe if there existed a "Space" button.)
You can modify Windows settings that would affect sizing, but that would affect all windows & not just Salamander.
(Now I do not like the Folder icons, feeling that they are too similar to archive [.zip] icons. Also don't like the font type-face. Much preferred [I think it was in Salamander 2.0] font & folder icons. [Yes, I know that the font can be changed, just never bothered with it.])
AS toolbar - 16x16 icons, text off
Competitors toolbar - 16x16 icons, text on
Where is the problem? Only difference is toolbar buttons size.
th.
Post by th. »
Especially on a laptop with touch pad and high-res display I think 24x24 or maybe even 32x32 tool bar icons would be handy.
murphy
Post by murphy »
The toolbar icons in 16x16 are ok for me, but it should be added an option to use 24x24 toolbar icons or bigger.
http://www.dev0.de / http://murphys.me
The problem is we have only 16x16 icons. It would mean up-scale existing icons or redraw complete icon set.
thomas
Post by thomas »
Up-scaling would be the worst solution. I like and prefer the smal icon bar.
I'd like to point out Gtein's previous attempt to redraw the toolbar icons in Czech part of the forum: Nové ikony (Google translate)
