When I need to copy lot of directories, I select a directory, but sometimes I need to check the content of a directory before.
So I go into the directory, but when I come back, all the selection is gone.
Would be nice to have an option, where I can choose ' Remember the selction for this directory', so when I come back the selection is still there.
Thanks
Eric
Request: Remember selection of files/dir
Re: Request: Remember selection of files/dir
I'm using Ctrl+Shift+Left and Ctrl+Shift+Right in this case. Directory is displayed in the target panel.
See Altap Salamander Keyboard Shortcuts.
Thanks, yes, this could do it.
Only need to change my custom/behavior
Or you can check Ctrl+Shift+F5/Ctrl+Shift+F6 to save and load the selection before leaving /after returning to that directory.
Great, didn't know that.Tomas Kopal wrote:Or you can check Ctrl+Shift+F5/Ctrl+Shift+F6 to save and load the selection before leaving /after returning to that directory.
Seems I'm not a power user at all.
RTFM.
Thanks
See menu Edit > Advanced > Save (Load) Selection.Tomas Kopal wrote:Ctrl+Shift+F5/Ctrl+Shift+F6
