Unpacker: .cbr/.cbz issue
otrov
Post by otrov »
I was exited by DN/NDN back in ASCII time, but I must say that this app is all I need and don't go anywhere without it (you know when you get used to some software and when it misses from the system it's just too bad feel :D) so thanks for making it
It has everything I can imagine and it's dirty fast in it tasks
Old windows controls doesn't bother me
OK, I've said it ;)
The reason for joining in here is a minor bug: salamander recognizes .cbr/.cbz files, but when unpacking .cbz (which are ZIP packed) it assumes it's RAR archive
Take care
Re: Unpacker: .cbr/.cbz issue
Hi, did you change archives associations in AS configuration? Mentioned extension are not associated with archives in the default configuration.
otrov
Post by otrov »
Hey,
I didn't change associations and actually was surprised when I tried unpacking .cbr and it worked, but then many things just work in salamander so I thought it's a feature
It's comic book archive which can me made easily by packing some .jpg files and changing extension to .cbr/.cbz depending of packer
[edit]
Well it's really not big deal, I associated now .cbz with ZIP plugin
.cbr worked as UnRar was by default set as unpacker, silly me :D
