Right click drag-n-drop move with Subversions files
pederalm
Post by pederalm »
Hi
If you are trying to move Subversion revision controlled files in Windows Explorer, using mouse right click drag-n-drop, you get a menu with 8 options (see Clipboard01.jpg). If you are doing the same move operation in Altap Salamander you only get 4 options in the menu (see Clipboard02.jpg). I find this to be a bug.
Move in Windows Explorer
Move in Altap Salamander
Re: Right click drag-n-drop move with Subversions files
Thank you for this bug report. We can reproduce it but (probably) will not be able to fix it due to Windows drag&drop implementation.
Please update to final version 2.52.
Heh?
I'm able to use SVN commands after clicking the "Other..." item in the menu. I'm not sure, why it needs an extra click, but it worked for me for a long time ;)
pederalm
Post by pederalm »
Thanks! I have never tried the "Other" menu option, but it works :D
I wonder why the first menu doesn't show the SVN-menu options instead of the "Other" menu. Strange....
It's limitation of current implementation. It could be solved using shell extension that Salamander already has. We have this task on our todo list.
