FTP Bookmarks lost
FTP Bookmarks lost
I just found out that all my FTP Bookmarks are not showing in ver. 2.52
Is there any way I could recover them?
Thank you,
Docfxit
Thank you,
Docfxit
Re: FTP Bookmarks lost
Please check Registry key HKEY_CURRENT_USER\Software\Altap and look for older versions of Salamander.
Bookmarks are placed (for example) in HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.51\Plugins Configuration\FTP\Bookmarks
Do you have your lost bookmarks there?
Thank you for the reply.
Under Altap all I have is:
Altap Salamander 2.52
Applications
Servant Salamander 2.0
Would I be able to recover the bookmarks from someplace else?
Thank you,
Docfxit
Applications
Thank you,
Docfxit
It doesn't look good.
Do you have some backups of registry or Windows Restore Points? Unfortunately I don't know if is it possible to extract Registry hives from restore points? Does anybody know? Is HKEY_CURRENT_USER key part of restore points?
Yes, the HKCU is a part of system restore point.Jan Rysavy wrote:It doesn't look good.
Solution depends on windows version.
1) Change access right on C:\System Volume Information so you can read it
2) find the latest restore point entry where your FTP bookmarks worked (sort by date)
3) locate the subfolder Snapshot where the registry backups are
4) Locate your user hive _REGISTRY_USER_NTUSER_S-<long user id> and copy the file to a temporary location i.e. C:\temp
5) rename the file in C:\temp to myreghive or something similar
6) start regedit
7) go to HKEY_LOCAL_MACHINE, click File -> Load hive
9) open HKEY_LOCAL_MACHINE > test > software > Altap > Plugins Configuration > FTP > Bookmarks
10) let the Bookmarks be highlighted and go File > Export
11) name the exported file myregfile.reg
12) go to HKEY_LOCAL_MACHINE > test and then File > Unload hive
13) close regedit
14) open the exported registry file in notepad
15) replace all occurences of "HKEY_LOCAL_MACHINE\test" by "HKEY_CURRENT_USER" so the path looks like this "[HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.52\Plugins Configuration\FTP\Bookmarks]" and save the reg file.
16) Now make a restore point in case something goes wrong (start %SystemRoot%\system32\restore\rstrui.exe)
17) Close SALAMANDER and import the entries in to the registry by hitting enter on the modified file.
18) start Salamander and check your bookmarks
This is the "hard" way...
The easy way is to restore the system state with a older restore point using systenm restore (%SystemRoot%\system32\restore\rstrui.exe).
SelfMan, looks good, thank you!
I didn't know about option to mount offline Registry hive until recently.7) go to HKEY_LOCAL_MACHINE, click File -> Load hive
Nice.SelfMan wrote:Yes, the HKCU is a part of system restore point.
Steps 10, 11, 14, 15 can be replaced by using Salamander's Registry Plugin (navigate to both registry keys and copy), but you have to ensure that Salamander won't rewrite its configuration upon exit (using the option in the Configuration dialog, or by terminating the process).
And of course, in any case, you shouldn't forget to set the System Volume Information's permissions back to how it was before.
Its been there alon timeJan Rysavy wrote:SelfMan, looks good, thank you!
@ether
I made the list on purpose without salamander. It's not healthy at all to mess with the programs own registry while its running.
Not really, you can mount registry hives under HKU, too.SelfMan wrote:The only problem was you had to be in HKLM to load it.
Ah true... mea culpa... I've never used this key for loading offline hives.ether wrote:Not really, you can mount registry hives under HKU, too.SelfMan wrote:The only problem was you had to be in HKLM to load it.
Since this thread was just mentioned ...
(I always use the cacls method myself.)
Accessing the System Volume Information Folder1) Change access right on C:\System Volume Information so you can read it
If I'm understanding correctly (& I certainly may not be) there may be other locations that may contain wanted data.
Like: C:\Documents and Settings\{username}\NTUSER.DAT
That a (shareware) program like RegdatXP may help with?
http://www.regdat.com/ a tool to manage non active NT based registry files.
http://www.regdat.com/rmrxp.htm
Great - its easy and working!
I do (almoast) whole procedure in AS.
Some notes:
-whole setup is only for Windows XP (W7 havent this simple files and folder structure of System Volume Information folder)
- I changed "System Volume Information" properties by "Ctrl+F2" (in AS) and removing Encrypted (or something like it, in czech "Šifrovaný"), I think you can remove all others too (hidden, system...)
- in point 5) you need to change file name on "enything.reg", and be sure, that this file (and folder - I have "C:/Temp" hidden too) isnt hidden (again "Ctrl+F2" in AS) - for better using this by Explorer later.
- after hive (Czech: "Načíst podregistr") backup file, i used whole "HKEY_CURRENT_USER\Software\Altap" part - it possible to restore anything around AS this way (and that is really great new) => I think AS would have some autobackup algoritm too.
- only one last think stay uncertain: Is necessary to restore properties on System Volume Information folder? Or some other "tweak back" things?
Some notes:
OK, now some notes and reactions from me:
^) Although it could get better at recovering the remains of damaged configuration data.
The Task Scheduler or psexec utility can be used to run an application (presumably the Registry Editor) under the SYSTEM account which has full permissions on the System Volume Information directory, so you don't have to mess with them.therube wrote:1) Change access right on C:\System Volume Information so you can read it
Sure, but it's not likely - you'd have to have a good backup somewhere.therube wrote:If I'm understanding correctly (& I certainly may not be) there may be other locations that may contain wanted data.
That's the current (working copy) registry hive, this hive doesn't contain the data we want - that's why we looked for other hives in the first place.therube wrote:Like: C:\Documents and Settings\{username}\NTUSER.DAT
That's odd, I don't remember anything about SVI being encrypted, this is probably a change you or some application did.fraktik wrote:I changed "System Volume Information" properties by "Ctrl+F2" (in AS) and removing Encrypted
You actually don't want to do that, registry hives (usually without any extension) are stored in a different format than registry export files (.reg) and if you add this extension, you're exposing yourself to the risk of opening the file in a wrong way (which will probably just summon an error message and don't do any damage, but you probably want to be on the safe side when dealing with the registry).fraktik wrote:in point 5) you need to change file name on "enything.reg"
Yeah, it could, but since there's a lot of good backup programs already, I don't see why AS should care about that. (^)fraktik wrote:I think AS would have some autobackup algoritm too.
It's not necessary, it's just recommended.fraktik wrote:only one last think stay uncertain: Is necessary to restore properties on System Volume Information folder? Or some other "tweak back" things?
"RegFileExport"
http://www.nirsoft.net/utils/registry_f ... xport.html
"RegFileExport is a small console application that allows you to easily extract data from offline Registry file located on another disk drive. RegFileExport read the Registry file, analyze it, and then export the Registry data into a standard .reg file of Windows. You can export the entire Registry file, or only a specific Registry key.
RegFileExport may also be able to export some of the Registry data even when the Registry file is corrupted and cannot be loaded by Windows."
Example (& split onto multiple lines only to aid readability):
output_data.txt:
C:\BIN\UTILS\Nirsoft> regfileexport.exe
"C:\System Volume Information\_restore{A3FE4697-A95B-4476-A0D8-DD1DBA7304B7}\RP1792\
snapshot\_REGISTRY_USER_NTUSER_S-1-5-21-1184441913-3557630161-3586670608-1010"
"output_data.txt"
"HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.54\Plugins Configuration\FTP\Bookmarks"
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.54\Plugins Configuration\FTP\Bookmarks]
[HKEY_CURRENT_USER\Software\Altap\Altap Salamander 2.54\Plugins Configuration\FTP\Bookmarks\1]
"Name"="ALTAP"
"Address"="ftp.altap.cz"
"Initial Path"="/pub/altap/salamand"
"Anonymous"=dword:00000001
