Drag and drop of attachments from Outlook 2007 to Salamander doesn't seem to work (Salamander 2.52, Win7, run as admin)
Otherwise drag and drop to other applications and desktop works OK.
Could be I'm missing something here but I would appreciate help on this since it's a productivity killer to save attachments "regular" way. Thanks
Outlook 2007 attachment drag and drop
Re: Outlook 2007 attachment drag and drop
Try to run Outlook "As Admin" too. Or Altap Salamander as regular user. Does it help?
Indeed, running Outlook as admin did the trick.
Must admint that would probably be the last thing I'd consider.
Anyway, many thanks for the immediate help.
You should probably vote for UAC: http://forum.altap.cz/viewtopic.php?f=4&t=3597
You need to run Salamander as standard user and have option to escalate particular operations.
