Portable Altap Salamander
plino
Post by plino »
You have mentioned in this post
http://forum.altap.cz/viewtopic.php?t=2431
that it would take long to migrate to INI file.
However in another project I collaborate (an Open Source alternate shell for Windows named Emerge Desktop) the single developer migrated the configs to XML using the tinyXML library...
This would be perfect for people who carry their AS in a pen
Georgd
Re: Portable Altap Salamander
Post by Georgd »
@Altap: Is XML easier? Portable Salamander would be great :)
Using Salamander since v 1.52
vld
Post by vld »
Georgd wrote:Portable Salamander would be great :)
Here is something that will make any Salamander portable http://forum.altap.cz/viewtopic.php?f=14&t=3084
Georgd
Post by Georgd »
vld wrote:Here is something that will make any Salamander portable http://forum.altap.cz/viewtopic.php?f=14&t=3084
This batch file is simple, but does the trick perfectly well. Thanks, vld! :-)
vld
Post by vld »
Thanks go to Eva Eden~ for the original design. I just modified it to fit my needs and now love carrying a generic configuration version of Salamander on my thumbdrive.
