The WinSCP plugin works quite well, but there is a problem with certain login-profile names: The Plugin displays all "Stored sessions" of WinSCP (basically a profile of target  server, login name etc.) and I can connect to all sessions. If the session is in a folder however, I cannot change directories after connect.
For example: I have two entries in WinSCPs "Stored sessions":
user1@someserver
folder1/user2@otherserver
I can connect to both, the Path field shows these paths respectively:
scp://user1@someserver/home/user1
scp://folder1/user2@otherserver/home/user2
If I try to change the directory on "otherserver" I get this error message:
"You are leaving SFTP/SCP server in panel. Do you with to disconnect or to keep connection to this server?
If you choose Keep, you can access this connection from the Change Drive menu later"
Needless to say, I wanted to change the directory on the remote server, not switch to another drive.
I have a lot of "Stored sessions" in WinSCP, I do not want to have them as one long flat list, but I want to use folders to organize them.
Greetings
Markus
						WinSCP Plugin: "Stored sessions" folders problem
				Martin Prikryl
Re: WinSCP Plugin: "Stored sessions" folders problem
This looks like a bug. Thanks for reporting it. I'll investigate it.
							Martin Prikryl
https://winscp.net/
						https://winscp.net/
Thanks, I'm looking forward for a solution.
Greetings
Markus
						Greetings
Markus
				Martin Prikryl
The problem has been fixed. The fix will be included in the nearest possible release.
							Martin Prikryl
https://winscp.net/
						https://winscp.net/
Martin: Many thanks for the timely fix. Can you give me the fixed Plugin before the next release? I.e. I could do some testing.
Greetings
Markus
						Greetings
Markus
Markus, we will release next Preview Build version of AS soon. You can try it there. See Early Access Program.
