Hello together,
I just wanted to know if there is a function like the linux tail in the salamander. Means if I look at a log-file which changes all the time, that the salamander jumps automatically at the end of the file. Ok, it is possible, but only if I press Ctrl+R or End in the viewer.
And is there a function for maybe highlighting the row, in which a word occurs (e.g. ERROR -> the whole line should get red)? This would be really great.
Regards
Internal Viewer: Tail mechanism
Re: Internal Viewer: Tail mechanism
There is a win32 version of tail command. There are other GUI tail's but they aren't as nice IMO. Search on google for win32 tail. If you find something good, let me know (I tail several logs during my developments).narkan wrote:Hello together,
Regards
HTH and Thanks
May i suggest an tool like ListXP
Stand alone exe.
Tailing. When a file has new data appended to it you can have
ListXP automatically refresh the display to include the new data. Since
ListXP only parses the new end of the file (instead of the entire file),
tail updates are very quick.
http://www.listxp.com/listxp_features.html
Just add an new viewer entry for your needed extensions
and assign ListXP to it.
I am not sure if View64 can tailing too.
More viewer suggestions are welcome
HTH
Stand alone exe.
HTH
Stefan
Pleased user since v1.52 - Licence# 0306-0046-01
Try this free text editor: Notepad2.narkan wrote:I just wanted to know if there is a function like the linux tail in the salamander. Means if I look at a log-file which changes all the time, that the salamander jumps automatically at the end of the file. Ok, it is possible, but only if I press Ctrl+R or End in the viewer.
It is small (540KB), fast and has even syntax highlighting for HTML and other common languages.
It is ideal replacement for Notepad.
This command jumps at the end of the file:
Notepad2.exe /g -1 "$(Name)"
You can customize built in schemes for highlighting whatever you need.
