FTP Client - CDUP
Zivan
FTP Client - CDUP
Post by Zivan »
Vytvoril jsem si na routeru Asus WL-500g FTP server a pres SS 2.52 se na nej pripojil. Narazil jsem na problem, ze mi nefunguje prechod do nadrazeneho adresare pomoci "..". Stejne chovani u pasivniho i aktivniho rezimu.
Pokud pouziji kontextovou nabidku, "Send FTP Command" a poslu CDUP, tak jsem o uroven vys - tedy vse OK.
Log:
Connecting to "192.168.1.1" (192.168.1.1) on port 21.
Log UID is 11, time is 30.10.2009 - 10:37:47.
220 Welcome to FTP server.
USER anonymous
331 Guest login ok, send your e-mail address as password.
PASS (hidden)
230 User anonymous logged in.
MODE Z
503 Command not understood.
INFO: Server does not support MODE Z -> compression disabled
(10:37:47): Logged in successfully, getting system information...
SYST
215 UNIX Type: L8 (Linux).
PWD
257 "/" is current directory.
(10:37:47): Changing path to "/"...
(10:37:47): Listing path "/"...
PORT 192,168,1,2,6,192
200 PORT command successful.
TYPE A
200 Type set to A.
LIST
150 OK
226 Transfer complete.
(10:37:47): Text listing was parsed by "UNIX1" server type...
(10:37:48): Changing path to "/ftp_pub"...
CWD /ftp_pub
250 CWD command successful.
PWD
257 "ftp_pub/" is current directory.
(10:37:48): Listing path "ftp_pub/"...
PORT 192,168,1,2,6,193
LIST
150 OK
(10:37:48): Text listing was parsed by "UNIX1" server type...
Reason: Logy zabírají moc místa - do [code]
Re: FTP Client - CDUP
Zivan wrote:Vytvoril jsem si na routeru Asus WL-500g FTP server a pres AS 2.52 se na nej pripojil. Narazil jsem na problem, ze mi nefunguje prechod do nadrazeneho adresare pomoci "..".
Bylo by mozne pozadat i o nasledujici logy?
1) s chybou pri prechodu pomoci ".."
2) s rucnim zadanim prikazu CDUP
3) s rucnim zadanim prikazu FEAT
Zivan
Post by Zivan »
ad1) V logu neni zadne info navic.
ad2) V logu navic:
(11:05:22): Sending user command "CDUP"...
CDUP
PWD
(11:05:22): Listing path "/" from cache...
(11:05:22): Text listing was parsed by "UNIX1" server type...
ad3) okno FTP Server Reply to "FEAT" - "503 Command not understood."
Zivan wrote:ad1) V logu neni zadne info navic.
Pri nejmensim by tam melo byt cislo chyby a textovy popis. V tom puvodnim logu nevidim "CWD .."
Zivan
Post by Zivan »
Zadna chyba nikde neni. Salamander se chova, jako kdybych zadnou cinnost neudelal. Do logu nepribude zadny radek.
Na FTP altapu vse funguje.
Problém by mohl být v listingu. Zkoušel jste nějaké jiné klienty, fungují?
Funguje ruční zadání CWD /adresar1/adresar2/.../?
Zivan
Post by Zivan »
CWD [adresar] funguje, dokonce funguje i prikaz "CWD .."
Zkusil jsem ftp klienta v Total Commanderu 7.50a a ten taky funguje. Podle logu pouziva TC prikaz CDUP.
Zkuste nám poslat listing (Plugins > FTP Client > Show Raw Listing...).
Zivan
Post by Zivan »
drwxr-xr-x 2 anonymous ftp 4096 Oct 30 08:44 ftp_pub
drwxr-xr-x 2 anonymous ftp 4096 Oct 30 08:44 ftp_pvt
drwxr-xr-x 2 anonymous ftp 4096 Oct 30 09:45 tbbt
Edit:
Vnorim se napr. do prvniho adresare, ten je prazdny a Raw Listing je taky prazdny. Zadne ..
Pres SZ odeslana IP adresa FTP
Vzhledem k tomu, že není problém několikero způsoby (CWD .., CDUP) přejít o úroveň výš, hádám, že problém bude někde mezi FTP Pluginem a Salamanderem.
Tipuji, že problém bude v odpovědi na PWD: "257 "ftp_pub/" is current directory.". Cesta "ftp_pub/" nezačíná lomítkem, jak by měla. Nejde to na FTP serveru opravit (někde v jeho nastavení cest)?
Přikaz CDUP nepoužíváme, vše se řeší textově zkracováním cesty.
Zivan
Post by Zivan »
Urcite spousta lidi umi upravovat nastaveni linuxu v routeru. Ja mezi ne ale nepatrim :)
Časem to zkusím nasimulovat a opravit, díky za ohlášení.
Právě jsem problém otestoval na našem ASUS WL-500g Deluxe s posledním firmware 1.9.2.7-10 (2008-03-30) a vše funguje.
Zřejmě půjde o jednu z oprav:
Stupid-ftp should now work with some linux ftp clients
Fixed ftp server bug, which prevented files to be uploaded to subdirectories
FTP: switched to vsftpd, reworked web-iface.
...atd
Aktualizujte si prosím firmware v routeru. Poznámka: jde o neoficiální firmware, který ovšem mohu jen doporučit. Pokud jste na oficiální řadě, zkuste update ze stránek firmy ASUS.
Do Salamandera tedy hack pro tuto chybu zanášet nebudeme (mohl by způsobit problémy u jiných uživatelů).
Zivan
Post by Zivan »
Pouzil jsem posledni neoficialni FW ze stranek koppel.cz a potvrzuji, ze FTP uz chodi.
Jinak pozor na to, ze na strankach Asusu je u WL-500g prvni FW v cinstine. Nic pro nasince :D
