Hi
I am trying to make a Silent install on my Windows Vista Professional SP1 Danish.
The files are copied and the Shortcut folder is created, but the shortcut2, Uninstall Regkey, remove.rlg file are not created.
It does'n matter if i use the /x /s parameter on the as251f.exe or if i extract the files and use /s on the setup.exe file.
Max Prang
Topdanmark
Silent installation
Re: Silent installation
I have fixed this bug. It will be in version 2.53 (also in its preview builds).
Silent mode worked only if license key (keys25.zip or keys.zip) was found near installer .exe (e.g. as251f.exe or as252f.exe). Otherwise installation was canceled preliminary after creating all directories and copying all files (skipped parts: creating shortcuts, registry keys and values, and saving remove.log). Thanks for reporting!
