Allow Focus when multiple files selected
mdruiter
Post by mdruiter »
If I select multiple files in Find, I can press F3 to view the "current" one. However, I cannot press Space to focus the current one in Salamander. Being able to do that would be very useful though, and I cannot think of a reason it should not be possible.
Groente, Michel.
Re: Allow Focus when multiple files selected
Michel, thank you for pointing this out. Also enablers for View/Edit commands were incorrect.
From AS 2.53 it will be fixed and you will be able to Focus file or directory the same way as you View it using F3.
